Auto bed level error Video.
dubbsd
Posted (edited) · Auto bed level error Video.
My first inclination without seeing any other information about your setup is to say that the bed is starting a bit too far away from the nozzles for the printer to compensate for the gap, hence the message that it "exceeds realistic values."
The first thing I would try is to manually level the build plate once to at least get things in the right range (The gear tab on the left of the screen > Maintenance > Build Plate > Manual Leveling). If you have the calibration card that came with the printer, this should be pretty straightforward; the printer will walk you through the steps on screen.
Edited by Crystalvalen
Accidentally marked up text with strikethrough. Edited to fix.
        • 4 replies
