Posted · slicing - aribtrarily ignoring small protrudings
Dear forum,
I'm using the Ultimaker 2+ and cura already for several years - without major issues so far. But recently I wanted to print a model with an protruding inscription. The size of the protruding is set to 0.2mm (for a test also set to 0.4mm) also the half of the nozzle diameter. When I slice the model not all protruding are covered by the track. For some layers in between they are just ignored (see first figure xxx_1.png). However, when I set the surface mode to 'surface' then the full details are printed i.e. covered by the path (see second figure xxx_2.png). Also the corners of the circle segment is printed without any corruption; as expected.
Does anyone know the reason or have a clue what the cause for the strange path generation might be?
Thanks for any hints and kind regards,
Ramón
    12 hours ago, DidierKlein said:
    Most probably the wall is to thin to be considered, you might need to check the print thin walls option in order to prevent this (or it's a problem in the design file
    But it also happens when the protruding is >0.8mm what is more than the nozzle size (0.4mm). The imported file is an .stl that actually only gives the shape - and when I only print the shape it is correctly done. So I doubt that it is an issue of the design. What might it be that only some parts are considered in the track?
    I've also ticked the option 'Print Thin Walls' but without success...
