I had the same errors when i built my machine last week, what i found is if you are using Rep26 and you install
a new firware but NOT via Rep26 you get these errors. But if you update the firmware via Rep26 (there is a marlin
build in there) then the machine will connect fine.
I have now got Printrun working, so i plan on trying Daid's "Build-my-marlin" firmware which i understand does not
work with Rep26, but works fine with print run.
Daid 304
I've seen the same problems when trying to print from my Vista laptop, and when printing trough a USB-HUB. It also worked at the start, but later didn't work anymore, no amount of rebooting/power down seemed to help. RepG also reported nothing more then you listed here.
Then I moved to my WinXP machine and the problems where gone.
