@ahoeben Well, I can't replicate the printer settings from the old version of Cura to the new version of Cura. Isn't that a problem?
11 hours ago, mbmast said:Isn't that a problem?
No. The new Cura represents the same data in a more correct way.
The head dimensions are only used for One-at-a-time printing anyway.
Edited by ahoeben- 3 years later...
On 12/10/2019 at 11:16 PM, mbmast said:I bought a CreatBot D600 Pro printer. This printer comes with the old style Cura software with the printer pre-configured (after selecting from a list of CreatBot printers). There's no export feature here, so I'm just manually copying the printer settings into the newer version of Cura. I'm running into a problem setting the printer head settings. When I specify X min and Y min values of 75.0 and 18.0 respectively, Cura (the newer Cura) resets them to -75.0 and -10.0, respectively. See image.
Why is it doing this? How do change these values?
Did you get it to work with the newer Cura? I'm searching for material profiles and settings to adjust for my D600 that my company has.
ahoeben 1,956
What makes you think this is a problem?
