28 minutes ago, Smithy said:When you connect the laptop via USB cable, then you print from your laptop. So be careful to not disconnect it or let it go to sleep. It is not a good idea to go that way, but your only way if your SD card is not working.
As far as I know your printer has no internal storage, so just sending the file to the printer via USB is not possible.
Thanks Smithy
I have one more question. When I attach the empty slot to the laptop it recognizes it, however, when I put sd card inside the slot the laptop cannot show it.
The sd card works inside 3d printer. So, could we conclude that the problem is with the slot itself?
Smithy 1,134
Turan 0
Thanks Smithy
