Cura 4.4 error at start
aarghh
Posted · Cura 4.4 error at start
Hi.
I've updated Cura form 4.0.0 and 4.2.0 to 4.4 on 2 computers and it's not starting on both. I've tried Administrator rights and Windows 8 compatibility and still nothing.
The errors shown:
Traceback (most recent call last):
File "X:\4.4-exe\build\inst\lib\python3.5\site-packages\cura\Machines\Models\IntentCategoryModel.py", line 101, in _update
File "X:\4.4-exe\build\inst\lib\python3.5\site-packages\cura\Machines\Models\IntentModel.py", line 40, in __init__
File "X:\4.4-exe\build\inst\lib\python3.5\site-packages\cura\Machines\Models\IntentModel.py", line 66, in _update
File "X:\4.4-exe\build\inst\lib\python3.5\site-packages\cura\Machines\Models\IntentModel.py", line 105, in _getActiveMaterials
KeyError: 'empty_material'
And logs:
Thread 0x0000048c (most recent call first):
File "threading.py", line 297 in wait
File "zeroconf.py", line 1569 in wait
File "zeroconf.py", line 1153 in run
File "threading.py", line 914 in _bootstrap_inner
File "threading.py", line 882 in _bootstrap
Thread 0x00002428 (most recent call first):
File "threading.py", line 549 in wait
File "C:\Program Files\Ultimaker Cura 4.4\plugins\UM3NetworkPrinting\src\Network\ZeroConfClient.py", line 74 in _handleOnServiceChangedRequests
File "threading.py", line 862 in run
Thread 0x00001fb4 (most recent call first):
File "zeroconf.py", line 1017 in run
Thread 0x00000994 (most recent call first):
File "zeroconf.py", line 946 in run
Thread 0x0000257c (most recent call first):
File "C:\Program Files\Ultimaker Cura 4.4\plugins\RemovableDriveOutputDevice\RemovableDrivePlugin.py", line 61 in _updateThread
Thread 0x00001ca0 (most recent call first):
File "C:\Program Files\Ultimaker Cura 4.4\plugins\USBPrinting\USBPrinterOutputDeviceManager.py", line 86 in _updateThread
Thread 0x00002710 (most recent call first):
File "X:\4.4-exe\build\inst\lib\python3.5\site-packages\UM\Backend\Backend.py", line 150 in _storeStderrToLogThread
Thread 0x0000188c (most recent call first):
File "X:\4.4-exe\build\inst\lib\python3.5\site-packages\UM\Backend\Backend.py", line 138 in _storeOutputToLogThread
Thread 0x00001edc (most recent call first):
File "threading.py", line 293 in wait
File "threading.py", line 424 in acquire
File "X:\4.4-exe\build\inst\lib\python3.5\site-packages\UM\JobQueue.py", line 86 in _nextJob
File "X:\4.4-exe\build\inst\lib\python3.5\site-packages\UM\JobQueue.py", line 112 in run
Thread 0x00002578 (most recent call first):
Thread 0x00001a68 (most recent call first):
Thread 0x00000668 (most recent call first):
Current thread 0x00002608 (most recent call first):
File "X:\4.4-exe\build\inst\lib\python3.5\site-packages\cura\CrashHandler.py", line 306 in _logInfoWidget
File "X:\4.4-exe\build\inst\lib\python3.5\site-packages\cura\CrashHandler.py", line 156 in _createDialog
File "X:\4.4-exe\build\inst\lib\python3.5\site-packages\cura\CrashHandler.py", line 77 in __init__
File "X:\4.4-exe\build\inst\bin\cura_app.py", line 111 in exceptHook
File "X:\4.4-exe\build\inst\lib\python3.5\site-packages\cura\CrashHandler.py", line 391 in _show
File "X:\4.4-exe\build\inst\lib\python3.5\site-packages\UM\Event.py", line 189 in call
File "X:\4.4-exe\build\inst\lib\python3.5\site-packages\UM\Qt\QtApplication.py", line 428 in event
File "X:\4.4-exe\build\inst\lib\python3.5\site-packages\cura\CuraApplication.py", line 1003 in event
File "X:\4.4-exe\build\inst\lib\python3.5\site-packages\UM\Qt\QtApplication.py", line 341 in exec_
File "X:\4.4-exe\build\inst\lib\python3.5\site-packages\cura\CuraApplication.py", line 804 in run
File "X:\4.4-exe\build\inst\bin\cura_app.py", line 180 in <module>
File "Console.py", line 24 in <module>
File "<frozen importlib._bootstrap>", line 634 in _load_backward_compatible
File "<frozen importlib._bootstrap>", line 664 in _load_unlocked
File "<frozen importlib._bootstrap>", line 957 in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 968 in _find_and_load
File "__startup__.py", line 12 in <module>
What can I do?
Thanks for help in advance.
    • 2 weeks later...
    I have the exact same problem with version 4.4.1:
    File "X:\4.4-exe\build\inst\lib\python3.5\site-packages\cura\Machines\Models\IntentModel.py", line 41, in __init__
    File "X:\4.4-exe\build\inst\lib\python3.5\site-packages\cura\Machines\Models\IntentModel.py", line 67, in _update
    File "X:\4.4-exe\build\inst\lib\python3.5\site-packages\cura\Machines\Models\IntentModel.py", line 109, in _getActiveMaterials
    Logs:
    Thread 0x00001244 (most recent call first):
    File "E:\Windows\Programme\Ultimaker Cura 4.4\plugins\USBPrinting\USBPrinterOutputDeviceManager.py", line 86 in _updateThread
    Thread 0x000006d0 (most recent call first):
    Thread 0x0000600c (most recent call first):
    File "E:\Windows\Programme\Ultimaker Cura 4.4\plugins\UM3NetworkPrinting\src\Network\ZeroConfClient.py", line 74 in _handleOnServiceChangedRequests
    Thread 0x00006268 (most recent call first):
    Thread 0x00005f14 (most recent call first):
    Thread 0x00003540 (most recent call first):
    File "E:\Windows\Programme\Ultimaker Cura 4.4\plugins\RemovableDriveOutputDevice\RemovableDrivePlugin.py", line 61 in _updateThread
    Thread 0x000050d8 (most recent call first):
    Thread 0x0000580c (most recent call first):
    Thread 0x00006554 (most recent call first):
    Thread 0x000053c8 (most recent call first):
    Thread 0x00004b7c (most recent call first):
    Thread 0x000005fc (most recent call first):
    Current thread 0x00002d7c (most recent call first):
    go into directory my computer>user>(whatever your user name is)>appdata
    (if you dont see appdata you need to show hidden files in that folder.)
    now go into local and delete cura folder
    then go into roaming and delete cura folder.
    relaunch your program and it should work.
    • Thanks 1
