I wasn't sure if it mattered for the version of Cura, so I saved both.
It's related to how the layers are created from the model's polygons. There's a setting called Slicing Tolerance that defaults to "middle". If you set that to "inclusive" that area of support doesn't get removed. However, doing that may also change the shape of the printed object so it may not be a good solution. Alternatively, I found that increasing the initial layer height to 0.3 filled in that missing area. My guess is that the region of the model immediately above where the missing support is must be at a slightly different height than the rest. Hope this helps.
And a 3rd workaround is to lower the model by 0.01 mm into the build plate.
Thanks so much I'll try some of those things. I'll look at the model as well, but just found it weird.
burtoogle 515
Hi, if you could save the project (File -> Save) and then attach the .3mf file to this thread it would be a lot easier to investigate. Thanks.
