12 minutes ago, ahoeben said:Unfortunately, due to a design flaw in the Marketplace, only one version of a plugin can be available in the Marketplace at a time.
I've done a fresh install of Cura 4.2.1, removing the user/Application Support/Cura folder from my Mac before making the install.
So I should have been able to retrieve the plugin from the Marketplace, as I've done for your plugins without any problem.
Is there any other location on macOS for Cura to store the settings and plugins ?
ahoeben 2,047
Unfortunately, due to a design flaw in the Marketplace, only one version of a plugin can be available in the Marketplace at a time. This means that if a plugin needs to be updated for newer versions of Cura, the author of the plugin must take additional steps to make sure that the plugin is also compatible with previous versions of Cura, or it will vanish from the Marketplace for those previous versions.
The authot of the RRF plugin makes previous versions of the plugin available here:
https://github.com/Kriechi/Cura-DuetRRFPlugin/releases
You will have to manually install these previous versions.
