I had the exact same thing happen to my select mini v2.
At the ends of the pipe that the filament goes though there are 2 couplings. On mine one of these broke and therefore created a block in the heatsink. Try to lock and then pull the pipe out, if it comes out easily
it's probably broken (duct tape can be a quick fix). There may also be a clog in the print head somewhere.
Not sure if your printer works the same but that's how I fixed mine
Edited by msmith0426
geert_2 556
I don't know your printer, so just guessing...
Maybe a blocked nozzle, and then the filament cooked, burned, and spilled all over, due to sitting too long in the hot nozzle? Or something along that line, where the filament got stuck?
Some materials burn away rather cleanly or leave black coal dust (like the PLA that I have), but some burn into a sort of glossy varnish that is hard to remove (like the PET that I have).
