heei about the calibration test,
i do te limit switch test but i think i do it wrong because when i start print he start on the right side... ?
en i think maybe the pulleys are wrong mounted are they are tight or loose?
ok 3D case heb me super geholpen vandaag! echt complimentje.
enigste probleem is nog dat het PLA extrude wieltje verkeerte som draait, iemand de oplossing ?
Everting is oke because 3DCase help me creat!
the only problem now is the extrude weel,
it drive to the wrong side
gr5 1,841
Explain more details. Does it fail connecting USB? Does it fail the limit switch tests?
Everyone at UM Support speaks dutch. There are nice people there who can help you and are in your time zone. They have been very busy but are finally caught up and would be happy to help you. I suggest you call them tomorrow.
Do you have a voltmeter? The voltage should be >10Volts. I think 19V. You could disconnect the connector at the fan and measure the voltage. If you have the Ulticontroller you can turn the fan on with that - set it to 255 (full fan).
Normally the fan doesn't come on until the second layer of printing (this is setting in Cura).
