Well i undestand is a problem with all this changes.
The fan is also noisy, i have problems with that fan, depends on the position it becomes very noisy. The sound is the motor, there's a vibration on it during half a second.
Is the stepper noise when you first turn on power? Or when you first start a print?
When i first turn power. Just X axis when i turn on power. I exchange motors, and i exchange controllers. it comes from the board, from the x out to the motor. So is not the motor it self. Is the electronics. Just it start after four or five days working.
Thanks for your comments and your interest. I've learned a lot with all your posts. Thanks.
gr5 1,967
I got my Ultimaker Original Kit a year ago. I ordered it and it showed up faster than I expected. I didn't have to call anyone. I didn't have any problems.
Could that be the fan on the bottom of the UM? It can be *very* noisy and the sound often stops after a few seconds. Many people have had trouble with that fan. You can remove the sticker and add a drop of oil if it gets worse. You can purchase a better one. I still have my original fan and if it gets noisy I hit my UM and the sound usually stops.
