Okay, so it seems that I could use both to compliment each other.
Just need to keep several desiccant bags on hand.
Thank you for your reponse.
You can dry the bag in an oven or with the Printdry, should work there as well, but more heat about 100°C is better I think.
I use also both, the food dehydrator to dry my spools and the Polybox for printing. I am not sure if the Polybox is really so airtight that you can store sensitive filaments for a longer time there, personally I store the spools in Lock & Lock boxes and use the Polybox only during printing.
I think that as long as you keep an ye on the humidity you can keep the stuff there for a few days. I am sure they tested their product.
A few days are not a problem, but I use PVA for example only every few weeks, so I am safer to store it in a really airtight box.
But you are right, I am sure the box works also for weeks.
we shall see. currently it is showing 10% humidity since yesterday afternoon. whereas the outside is at 55%.
so it appears to be working.
Smithy 1,135
The Polybox is just a place to keep your spool dry during printing. It doesn't dry the spool, just keep the air dry inside. So it only works if your spools are already in good condition. The cell battery is only for the small hygrometer to give an indication when you need to refresh the desiccant bags.
The Printdry is nothing else then a cheap food dehydrator which can actually dry a wet spool.
