Hi Daid,
I have installed mingw32-make and running make in the CuraEngine directory in the DOS prompt. I am getting the following error. Can you pls help us with set up of environment
C:githubmhkCuraCuraEngine>mingw32-make all
g++ -I. -c -Wall -Wextra -O3 -fomit-frame-pointer gcodeExport.cpp -o gcodeExport.o
In file included from utils/intpoint.h:12,
from utils/floatpoint.h:10,
from settings.h:4,
from gcodeExport.h:7,
from gcodeExport.cpp:4:
clipper/clipper.hpp:41: ostream: No such file or directory
In file included from utils/floatpoint.h:10,
from settings.h:4,
utils/intpoint.h:15: stdint.h: No such file or directory
In file included from settings.h:4,
utils/floatpoint.h:12: stdint.h: No such file or directory
In file included from gcodeExport.cpp:5:
pathOrderOptimizer.h:5: stdint.h: No such file or directory
mingw32-make: *** [gcodeExport.o] Error 1
Daid 303
Install mingw32
Run make
(In all honesty, if you need more instructions then this to get it to compile, you have little business in the code. It's a complex piece of code)
