CRAP !!!! I spent forever (well maybe an hour) searching for that option but just couldn't find it!
I did look in the settings visibility too, honest 😞
Thank you VERY much. I am making an eye doctor appointment on Monday !
the setting search box is very handy - you could have just entered brim and it would have shown you want you wanted to see.
In the past, the setting search box was not too helpful when searching for a word that wasn't the first and I got into the habit of not using the search function. Mind you, in this case I would likely have searched for 'support' and I should have found it.
Senility is setting in 😞
Enabled the option and voila ... it's implemented rather odd in that it doesn't do a brim around the individual support lines but the net outcome of better adhesion is the same.
Jens, I was trying to understand if there is a way to create a brim around the support as you mention, and it does work. The problem is that you have to make sure that "Brim only on Outside" is NOT checked.
burtoogle 509
Try the Enable Support Brim option...
Without...
With...
