Strange consistent flow issue with outter walls
Posted · Strange consistent flow issue with outter walls
Hello,
Im new here so forgive me if i am posting in the wrong spot.
I am running  CR-10S and am running into a strange issue ive been trying to figure out for a while. All of my prints are resulting in these weird ribbed lines all the way around my print on the outter and inner walls. It is not layer shift. the inner walls match the outter walls. Its almost like my flow is increasing itself and then decreasing. The lines are very consistent and equal length apart from each other. The over flowed lines are about 1.5mm tall and about 6.5mm apart from each other. This is resulting in me rigorously sanding this stuff out.
I am printing in 3D Warhorse PETG (I have used over 15 spools of this stuff)
As of now, and i am still experimenting but my current settings are:
Cura Ver. 4.2.1
Layer Height: 0.2
Line Width: 0.44
Wall Thickness: 2
Wall Line Count: 5
Top Layers: 4
Bottom Layers: 4
Top / Bottom Thickness: 0.8
Infill Density: 20%
Infill Pattern: Cubic
Infill Overlap Percentage: 1% (was experimenting with this)
Print Temp: 235
Bed Temp: 80
Flow: 113%
Initial Flow Rate: 113%
Retraction Distance: 5mm
Retraction Speed: 50mm
Print Speed: 37.5
Initial Print Speed: 7.22
Z Hop: Enabled
Cooling: Disabled
Please see photos and a small diagram I drew so you can see both sides of the walls. I am also including the GCODE of the photographed print. When you see the lines in the photos, note they are partially sanded so they are better visible.
Thank you to anyone who is able to help.
Part.gcode
