Solved. The model "came in" to Cura at some weird angles due to how it was designed. I took the STL back into Fusion (I think you could use Tinkercad as well) and reoriented the model. Once that was done, I brought it back into Cura and support blocker behaved like normal.
Edited by twlum Added Solved in case bots need it.
twlum 3
Edited by twlumAdded Solved in case bots need it.
