Devider plane in Cura ?
xeno
Posted · Devider plane in Cura ?
After a 30+hour print on my experimental Ultimaker+, I noticed that Cura put some kind of plane or divider into the drawing ?
It did not effect the printing as far as I can tell, but still am curious what this is.
    • 5 weeks later...
    I found out it is indeed a plane to show the current height of the print,
    but it does not show it all the time, it pops up more often when I do a Spiral contour print,
    but I cant find the trigger that makes it visible...DAID ?
    It should follow the Z height of the current print. It only shows if you haven't changed anything in the scene from the moment you started the print.
        How to Enter
        Design an Ornament
          Entering a new design
        Entering an existing design
        Winning designs should:
        Be original Creations
        Good luck 🎉
        • 1 reply
        • 13 replies
