Hi!
Thanks! That looks much better. However i still get some oozing...
The same retraction (30mm/s, 4mm) for my kossel delta (bowden) work fine with slic3r.
When i use cura (13.11) and the same settings i get a lot of strings.
Even if i set it to 70mm/s 6mm it looks still bad.
What does Cura differently than slic3r?
Another thing i noticed with cura: At the continuation point after retraction i get a weak (incomplete) fill.
Very strange... Any ideas?
Too bad, i really like the way cura calculates its toolpaths :( I do not want to switch back to slic3r :-
Regards,
Simon
Daid 306
Disable "combing"
