Infill blocker problem
Leggy
Posted · Infill blocker problem
Hi i put my cube in the part scale it but when i try to pull a face in the blue direction it goes in the red
pull it in the red direction it move in the green
very annoying any ideas thanks Dean
    This can happen if you rotate the model before adding the support blockers. The only workaround for now is to add the support blockers before rotating the model.
        • 21 replies
