Hi
If you just happen to catch the beast as it tries to unload:
A non-square tail end ( = one that is bent with a bit of a hook to it ...) on the filament can catch right at the Material Station feed mouth. It sits just inside the thing *almost* out in the open / headed to the spool. The firmware bashes away at the thing to try to get it to move past the point. It may / may not peal off a part of the end of the filament in the process. Cutting the end of the filament will indeed help with this problem. However a tapered end (which some rolls have) would be the ideal case. ( So yes, I have indeed seen the problem and caught it right at the point it was about to fail).
On some of the rolls that I have seen, there is the case of a "pinched" end. This one is not bent. It necks down right as it bends around into the hub of the spool. The result is about 5 to 10 mm of filament that is barely attached to the rest of it. Sometimes it falls off in the "bin" with the spool. Some times it makes it all the way into the system and back out again (still attached). Sometimes it comes out loose. I have a really nasty suspicion there is a case where it gets lost in the internals and jams things up ..... I have zero proof of that.
After about 10 minutes of carefully guided work / following the instructions from Ultimaker Support, my "A slot" problem is fixed. It was *not* a chunk of filament stuck somewhere. The issue was much simpler ( = loose connection).
Bob
Edited by uncle_bob
nickp100 1
Yes we also had the issue. The error thrown scraps the build though as nothing can clear it.
We are also having a lot of issues with loading Ultimaker PVA .
The material changer so far, at least for us, has created a lot more problems than it can potentially solve.
