S5 'Line nr = 0' Error
brian_prefix
Posted · S5 'Line nr = 0' Error
I keep getting this error message: "An error occurred while processing this print job. Line nr = 0". It's happened on multiple different print jobs. It also hangs up while trying to start a job, and also when trying to abort a job. Happened before & after the latest firmware update. Any thoughts?
    Hi
    If it's both WiFi and USB then there is an error at the start of the gcode. I normally grab a text editor and look at what it actually says. Often it's some "user definition" sort of line that some guy named Bob has put a type of  punctuation (that is not allowed) into.
    Bob
