Netfabb Support Options
markus_k
Posted · Netfabb Support Options
In NetFabb I believe the best (and really the only reliable option) is weak fluff support. This builds a bunch of branching towers from the bed up towards the overhands and then at the top few layers before the overhang it deliberately under-extrudes so that the actual support is 'fluffy' and easy to remove...
I rarely ever use support though... Best by far to avoid support as much as you can by careful placement / orientation of the model or splitting it up and gluing together.
Cheers,
Troy.
    I found the standard support to work with PLA and I mostly used weak fluff and fluff back when I printed PLA.
    I had to customize the settings for ABS. Here's an example, if you can copy and paste the following into a .reprapstyle file, you should be able to try it (for ABS). I wish I could figure out a way to simply attach the file here. :(
    <root>
    <name>09: Ultra quality - FILLED OBJECT</name>
    <outercontourwidth>fine</outercontourwidth>
    <minregionarea>0.30000001192093</minregionarea>
    <maxcontourlayers>2</maxcontourlayers>
    <upskinminwidth>3</upskinminwidth>
    <downskinminwidth>3</downskinminwidth>
    <fillingangle>45</fillingangle>
    <upskinangle>45</upskinangle>
    <downskinangle>45</downskinangle>
    <upskinlayers>25</upskinlayers>
    <downskinlayers>30</downskinlayers>
    <fillspacing>-0.125</fillspacing>
    <upskinfillspacing>-0.34999999403954</upskinfillspacing>
    <downskinfillspacing>-0.34999999403954</downskinfillspacing>
    <upskinfeaturesize>0</upskinfeaturesize>
    <downskinfeaturesize>0</downskinfeaturesize>
    <supportcalculationlayerthickness>0</supportcalculationlayerthickness>
    <supportdefaultangle>30</supportdefaultangle>
    <supportstrongangle>40</supportstrongangle>
    <supportweakangle>20</supportweakangle>
    <supportdefaultspacing>2</supportdefaultspacing>
    <supportstrongspacing>1</supportstrongspacing>
    <supportweakspacing>3</supportweakspacing>
    <supportminimumdiameter>0.5</supportminimumdiameter>
    <supportlayerdistanceondownskin>1</supportlayerdistanceondownskin>
    <supportlayerdistanceonupskin>1</supportlayerdistanceonupskin>
    <supporttransitionlayercount>15</supporttransitionlayercount>
    <supportpartconnectionlayercount>10</supportpartconnectionlayercount>
    <minimalhatchlength>0.80000001192093</minimalhatchlength>
    <supportfluffoverlap>4</supportfluffoverlap>
    <supportpartlockvolumeoffset>1</supportpartlockvolumeoffset>
    <regiondefinition1_outercontour>
    <filamentdefinition>half_layersize</filamentdefinition>
    <speed>snake</speed>
    <width>fine</width>
    <widthfactor>1</widthfactor>
    </regiondefinition1_outercontour>
    <regiondefinition1_filling>
    <filamentdefinition>default_layersize</filamentdefinition>
    <speed>slow</speed>
    <width>thin</width>
    <widthfactor>0.85000002384186</widthfactor>
    </regiondefinition1_filling>
    <regiondefinition1_upskin>
    <speed>slow</speed>
    <width>medium</width>
    <widthfactor>0.75</widthfactor>
    </regiondefinition1_upskin>
    <regiondefinition1_downskin>
    <speed>slow</speed>
    <width>fine</width>
    </regiondefinition1_downskin>
    <regiondefinition1_innercontour1>
    <speed>slow</speed>
    <width>fine</width>
    </regiondefinition1_innercontour1>
    <regiondefinition1_support>
    <speed>slow</speed>
    <width>fine</width>
    </regiondefinition1_support>
    <regiondefinition1_innercontour2>
    <speed>slow</speed>
    <width>fine</width>
    </regiondefinition1_innercontour2>
    <regiondefinition>
    <name>Normal</name>
    <minarea>-1</minarea>
    <maxarea>-1</maxarea>
    <zjumpoffset>0</zjumpoffset>
    <id>5</id>
    <temperature_scale>1</temperature_scale>
    <upskintype>0</upskintype>
    <downskintype>0</downskintype>
    <seamtype>1</seamtype>
    <outercontour>regiondefinition1_outercontour</outercontour>
    <filling>regiondefinition1_filling</filling>
    <upskin>regiondefinition1_upskin</upskin>
    <downskin>regiondefinition1_downskin</downskin>
    <innercontour1>regiondefinition1_innercontour1</innercontour1>
    <support>regiondefinition1_support</support>
    <innercontour2>regiondefinition1_innercontour2</innercontour2>
    </regiondefinition>
    <override>
    <name>support1</name>
    <speed>1.39999997615814</speed>
    <extruder>0.75</extruder>
    </override>
    <override>
    <name>support2</name>
    <speed>1</speed>
    <extruder>1.5</extruder>
    </override>
    <override>
    <name>support3</name>
    <speed>1</speed>
    </override>
    <override>
    <name>support4</name>
    </override>
    <regionselection>
    <type>bylayer</type>
    <threshold>2</threshold>
    <threshold>5</threshold>
    <threshold>9</threshold>
    <threshold>725</threshold>
    <item>
    <type>useregion</type>
    <regionid>5</regionid>
    <temperature>0</temperature>
    <heatedbed>100</heatedbed>
    <fancontrol>0</fancontrol>
    <speedoverride>50</speedoverride>
    <extruderoverride>100</extruderoverride>
    </item>
    <item>
    <temperature>100</temperature>
    <speedoverride>100</speedoverride>
    </item>
    <item>
    <heatedbed>75</heatedbed>
    </item>
    <item>
    </item>
    <item>
    <fancontrol>25</fancontrol>
    </item>
    </regionselection>
    <customization>
    <partinformation>\ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ </partinformation>
    <changetoextruder>\ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ </changetoextruder>
    <changefromextruder>\ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ </changefromextruder>
    </customization>
    </root>
