Cura appimage starting after each login despite it not running during logout -kubuntu 19.04 and 19.10
Posted · Cura appimage starting after each login despite it not running during logout -kubuntu 19.04 and 19.10
Describe the bug
Cura appimage starting after each login despite it not running during logout.
Expected behavior
It should not start automatically on login
To Reproduce
Steps to reproduce the behavior:
  1. download appimage
  2. add executable attribute
  3. click cura appimage
  4. choose to integrate it
  5. double check that it's not running in the background before logout (sudo ps -A)
  6. reboot/ re log
Tried to:
I added appimagekit_e2c5a07a925e9668276f846fb5d64def-cura(as I see the process name in ps) to "Applications to be excluded from sessions" - in Settings-> session management, but it makes no difference. I also checked "autostart" section there - no entries about cura
System, software and AppImage information
Operating System: Kubuntu 19.10
KDE Plasma Version: 5.16.5
KDE Frameworks Version: 5.62.0
Qt Version: 5.12.4
Kernel Version: 5.3.0-29-generic
OS Type: 64-bit
Processors: 6 × Intel® Core™ i5-8600K CPU @ 3.60GHz
Memory: 15,6 GiB
AppImageLauncher version installed:
Version: 2.1.0-travis897~d1be7e7+bionic
List of AppImages I tried:
  • Ultimaker_Cura-4.4.1.appimage
    What do you mean by integrating it?
    The only thing i do to run an appimage is to add the executable flag and double click it. It doesn't make any modifications to my system.
    Ubuntu AppImageLauncher has an option to "integrate" app image(screenshot) - it mainly adds it to app menu - it works fine for every other appimage I use except cura
