Yes, when I opened it with Cura I saw the notification that wasn't "watertight", but when I inspected my model with X-Ray view I coulnd't understand nothing, it was like everything with different tones of blue and purple. What can I do? Because in blender everything seems fine (not infinite thin walls, not any point or edge lost/repeated...)
Thanks for answering
ahoeben 1,963
If you inspect your model in X-Ray view (which is - strangely - hidden away in the Preview stage), you will probably see that there are geometry errors in your model. Your model likely isn't "watertight".
