Hi J:
I locate in Connecticut USA. I am using 0.4 mm nozzle. Most of the time, I use 1.75 mm PLA. It is a 600 X 600 X 600 mm printing zoom machine. Cura does not list this machine as one of pre-setup one. I like Cura than any other 3D slice application. Hopefully I can use it. Thanks!
Chip
JohnInOttawa 95
The Modix is an interesting machine. Still relatively rare so you might be a bit of a pioneer. Can you provide a bit of info as to where (generally) you're located, what print nozzle size(s) you are working with, filament type, etc?
Cheers
J
