I have. They print clearly when its just a single model.
I'll load another version of the model I have the same issue with.
Singles turn out like this.
Edited by Wideopentuning
10 hours ago, Wideopentuning said:I have. They print clearly when its just a single model.
No, you didn't. The model has a number of mistakes in it. In some cases Cura can fix these, in some cases, it can't.
On 3/2/2020 at 12:51 AM, nallath said:No, you didn't. The model has a number of mistakes in it. In some cases Cura can fix these, in some cases, it can't.
I don't think I understand the original question then. I did extrude the text from the model in Fusion 360 and when I print a single in Cura, I get results like the picture above. If I duplicate the model, the text is gone after I slice it and then preview and/or print. I loaded another version of the model that hasn't been ran through a repair tool.
I appreciate the responses.
I can see that there are some areas, but there are also faces where there should be none. That causes the issues.
burtoogle 508
It looks like you haven't subtracted the text holes from the body?
