Sounds like we're talking about the original Ultimaker.
Why does it make printing impossible? If the covers are over the holes, it shouldn't make too much difference. All that's happening is that when the belt moves the head in Y, it is pulling the axis rod with it, rather than sliding over it. That doesn't really make much difference, except for moving the X-axis pulleys back and forth a bit.
Start by adding some lubricant to the axis rods, so that they are less likely to stick. Sewing machine oil works well.
The back and forth slap can be annoying, of course, and it's certainly isn't ideal for print quality overall, so you might look at printing some replacement end caps such as Jeremie's parametric ones:
Or their derivatives (I just use the standard ones, fwiw.) These allow you to adjust the height of the center 'pin' as needed to hold the rods in place with minimal movement. You just need to be careful not to put too much pressure on the rod ends, as they do have to be able to rotate freely.
illuminarti 18
http://www.thingiverse.com/thing:23835
