@Carla_Birch We have the same problem with PVA on the S5, here. Both with and without the material station, PVA appears to be so brittle, it breaks very often during transport to the printcore. Once, it even shattered to small pieces inside the extruder enclosure so we had to dismantle it to get everything out. Adjusting the feeder tension is something we had thought about just recently, but is there a suggested procedure of doing that? I assume the tension has to be smaller, but how can I see when it is too small or even has the right tension? Any help or pointing in the right direction is highly appreciated.
Thanks,
Andy.
Carla_Birch 116
User Manual
https://ultimaker.com/download/74047/UM180509 UMS5 Manual V18.1.pdf
1) You might need to adjust the feeder tension, also PVA gets wet fast and that can give feed problems.
2) check user manual
3) Yes you can, You upload them via wifi, ethernet or cloud
Edited by Carla_BirchLink to post
