Can i "artificially" generate gaps between first layer lines? PIC!
swatti
Posted (edited) · Can i "artificially" generate gaps between first layer lines? PIC!
My first layer tends to overlap. If increase "line width" to 200%, cura will try to widen the print to that. If i increase layer height, once again cura tries to compensate by extruding more.
What i want is to do the "200% line widths" but with and actual "100% width" leaving gaps between every line. These i would then over-extrude and fill via that way, gaining good adhesion.
Edited by swatti
    Posted · Can i "artificially" generate gaps between first layer lines? PIC!
    2 hours ago, bagel-orb said:
    Reduce their initial layer flow.
    Alternatively, adjust your bed height physically.
    Lowering flow or printing higher wont work. That just reduces the contact surface.
    I want to have the wall-lines wider/further apart from each other, like the infill in the pic is. I want to then add over-extruding that will squish the filament down to addhere better.
    The infill comes in perfect, but the walls are too close and overlap.
    I hope you understand what im trying to do here.
    So what you do is set the line width to 200%, but set the flow to 50%, so that in the end the lines are extruded 100%, but spaces 200%.
    Niiiice. These settings look like they do the thing.
    Big thx, once again.
        • 24 replies
