Survey: Understanding your workflow
SandervG
Posted · Survey: Understanding your workflow
Hello!
Together with the software prototyping team we would like to validate some ideas that we have about our future product roadmap. In order to do this properly, who better to talk to than our very own users. So if you have a moment to spare we would appreciate it if you could fill out our survey (below).
All input we collect via the survey will be useful, and on top of that we'd like to select a couple users for a more in depth conversation, for the duration of approximately 1 hour (upon your availability). During this call we will let you interact with future concepts and aim to collect your feedback and opinion. In particular, if this would/could be a welcome addition to your 3D printing workflow.
Interested?
You can find the survey here.
Who do we hope to talk to?
The product roadmap is tailored to connected Ultimaker products, so you would need to own an Ultimaker 3 or Ultimaker S3 / S5 in a professional environment. It would be extra relevant when multiple people have a role in your additive manufacturing / 3D printing workflow. For example, where there is an operator, a CAD designer, or multiple operators.
Questions?
Feel free to ask them below!
Thank you for your time!
    • SandervG pinned this topic
    • 1 month later...
    Feature Requests
    1. Ability to select 1 or more of several models being printed at once, and halt the printing of that model without impacting other models being printed and allowing them to finish
    2. Ability to tune the printing process realtime with various parameters such as tool speed, tool temperature, bed temperature, fan speed, and filament flow rate
    • 4 months later...
    I'm very new to this and using Cura to adjust my prints on an Ender 5 Plus.
    Not sure if your insight request for for hardware or software.
    Using Cura it would be nice to have an export of the entire visibility settings. Could be text but .docx or ,pdf would work. I could then add space for my notes to add or exclude based on the project.
    There is an export function but it creates a cura enable file type. *.curaprofile
    ty
    Phil
    • 2 years later...
    When using an S5-Pro, allow a method for changing spools at a specific layer. For example, a color change.  It seems that if it can change spools when one goes empty, it should be a fairly simple process to allow the insertion of a bit of G-code to instruct a material change.
