Posted
· UM3 printing T-glase or nylon for COVID visors
I would at least try a couple in PLA. I have seen others who made things in PLA for emergency use too, recently. And I have also made prototypes in PLA for single use, to be desinfected with the usual 70% alcohol, or with some sort of chlorine solution (not sure about exact formula).
3D-printed tools are never optimal due to the pores, voids, and irregularities that collect "finger-mud". But this is for all materials, even PET and nylon. So you should make people aware that this is only an emergency solution, and that these pores are the draw-backs of this technology.
If you would be familiar with ABS printing, you could do acetone-smoothing until it has a high-gloss. (I am not, so I can't give tips.)
Acetone-smoothing also works on PLA (most of them), if printed in thin layers, but far less than on ABS. It tends to close some of the tiny gaps, but not bigger ones, and does not produce high-gloss surfaces.
The only real disadvantage of PLA is that it is bio-degradable, but I don't know how fast and how much is it eaten by hospital bacteria, if any? At least, bacteria haven't eaten my sifts and tools in my lab, even not the always moist ones in the sewer.
The advantages of PLA might outweight the disadvantages here: it prints fast, has good layer-bonding, good bed bonding, well known printing parameters, predictable results with very few failures.
If you print in thin layers (0.06mm or 0.1mm) at slow speeds, it is watertight. If printed at higher speeds and higher layers (0.3mm), it is not watertight, in my experience.
geert_2 558
