Cura wont print via usb
mechanicmem
Posted · Cura wont print via usb
Hello, I have a very strange problem, I just can't print directly from the program, when I start it it heats up the table normally, executes some preparation commands, but then it just stops suddenly, every time i try to print it stops in a different stage.
The strangest thing is that if i use the option to save and then open the print instructions (g-code file) on another program it prints normally, what could be happening?
By the way, the printer I use is a custom one.
Thanks!
      • 27 replies
