Posted
· Estimated print time Vs. Actual print time
I actually got time to watch a print in action today. On the layers without infill, the time remaining counter on the display basically tracked with the clock. On layers with infill, I started losing time (the time remaining did not keep up with the clock). I lost about 30 minutes on this 8 hour print. Once it got past the infill layers, it began tracking with the clock again.
I need to try using a different infill on the next print job, to see if it is just a Gyriod issue, but that will have to be a different day.
CTotten 18
