S5 Capacitive sensor lead broken
JVorders
Posted · S5 Capacitive sensor lead broken
Well this was a frustrating one. After many months of smooth running, our S5 started failing the auto bed levelling before even making the first contact point, and it would fail consistently after that showing the error message "Difference between detected height of both PrintCores exceeds realistic values". Replaced print cores, cleaned the bed, rebooted and rebooted, then after a while I discovered the connection to the sensor inside the fan bracket has sheared. This seems like a huge weak point considering how often the fan bracket is opened and closed. So just a heads up really!
    • 1 month later...
    Just to bring this one back up to the surface, this problem occurred again last week and repairing the broken wire was extremely fiddly. These wires could seriously use some kind of strain relief, or at the very least having their connection to the sensor moved away from the hinge point of the fan cover.
