when i click export in the plugin, i get a empty csv sheet.
so i dont know how to start.
Is it possible to change the currency? I tried to change € to $ on the first line of the .csv and then re-import and that didn't appear to work.
The plugin takes the currency from Cura (as set in the General preferences). If the currency specified in the csv file and in Cura does not match, the plugin will tell you so and (at this point) won't import the values. I have considered adding currency conversion in a future version, but sofar other projects have been more important.
How would I set it up so that its 11 cents per gram of generic PLA?
You don't need the plugin for that.
In the Materials pane of the preferences, you enter how much material (in Kg) you have on a spool and what a spool costs you. So if you enter you have spools that have 1 Kg of material, and each spool costs you 110 (dollar? euro?), then the material costs you 11 cents per gram. (Quite the expensive PLA!)
What the plugin will let you do is make changes like this for lots of materials in a spreadsheet and import that back into Cura, instead of filling this in material by material in the Materials preference.
Edited by ahoeben
ahoeben 2,047
You export data into a CSV file, which you can open in a spreadsheet application. Only editing the weight per spool and cost per spool is supported when importing the edited CSV file back into the plugin.
