Thanks for your prompt reaction. Those days I voluntired to print a part for a face sheild fused by the coronavirus fighters using an STL file I received. The problem is that when printing ends the nozzle is near fo touching the surface of the print and makes difficult to remove the part. I'm interested to add/change the last Gcode before printing stops so, the hotbed will move 20 - 30 mm from the product surface. I do not know how to see the "Gcode edit" window.
Your kind help will be more than appreciated.
Abraham Gome
SandervG 1,522
Hi @abrgome I've created a new topic for you in the correct sub-category (Cura). This increases the chances of someone reading your question who knows the answer. Perhaps, in the meantime, you can elaborate a little bit on your question.
Is Cura not producing gcodes, or do you not know how to do it?
Thank you,
