Cura and Repetier different result
wrtdgary
Posted · Cura and Repetier different result
Hi I am new to 3D Print.
I am having trouble of setting up the print model.
Recently I start to print with Cura software, And I've found out that the mashine will always print an extra line outside the model.
I did not set up the line and did not showed up in my Cura slicing. But when I put it into Repetier I can see the line clearly.
It is actually at the layer 1 of Repetier but nothing else. And the layer one of Cura starts from the layer 2 of repetier.
Does anyone know what couse the problem?
Thank you
        • 24 replies
