Ultimaker 2+ Estep calibration with data, variance ok?
Posted
· Ultimaker 2+ Estep calibration with data, variance ok?
9 hours ago, X-Type said:
First of all a notice on what I assume is some kind of bug. The first extrusion run after every M92 change of the estep value, gives a way off result.
For older versions of Marlin (like the one that is used in UM2) the current axis position is lost after M92 (or better: is not longer accurate).
Don't use M92 on its own, always send a subsequent G92 Exxx.xx to reset the position.
So, I have tested three extrusion lengths 100mm, 200mm and 300mm. It seems the longer extrusion run, the less filament is extruded.
I don't know the specific reason why you took all these measurements, but i think the used speeds are way to fast and the filament probably just slips more and more the longer the move takes.
I would use an equal (and lower) speed for all tests. Let's say F180 or even slower (somewhat closer to 'normal' extrusion rates). The variation should be much smaller then.
tinkergnome 929
