Hi Josnoww,
I can confirm the issue, with deactivated uniform scaling:
When I adjust the Z percentage the X percentage changes.
When I adjust the X percentage the X mm AND the Z percentage changes too without changing the Z mm.
When I change the X mm value both the X and Z percentages change.
When I change the Z mm value only the X percentage changes.
The only values working correctly are the Y fields
I have this behaviour with every stl file.
entering the values in mm is the only way to get the settings right
Josnoww 1
Hi BJohan,
I am not able to reproduce this issue. Could you save your project as a .3mf file and upload it?
Jos
