Weird anomaly that is repeated in every print
ProtoMac
Posted · Weird anomaly that is repeated in every print
Hi
I am printing PPE parts for our medical workers. We received the STL from the project coordinator with suggested settings for Cura. I normally use Simplify3D but the print took much longer than expected. So I switched to Cura with the latest download and the print time was in line with the predicted time. However, I have a strange anomaly at one place in the part that is identical for all parts. I did a re-slice but it seems to stay the same .
The top part in the picture was printed with Simplify3D and the bottom one with Cura. Seven parts after that are all identical. As if the error is actually part of the gcode.
The printer is my own build based on a Cron (local company)
CFFFP_Viziera Reinforced (Repaired).3mf Viziera Reinforced (Repaired).gcode
    If you are using combing, set the max comb distance with no retract to something like 10.
    If you are printing PETG you may find that turning off combing completely is best.
        • 24 replies
