Of course! Here's one example. Other objects in that same batch also have the issue, but for me, it can be replicated with just this one.
Thank you so much! And wow, this is crazy! Before exporting my STL file from Blender, my normals look fine! Then when I import my STL file again, the normals look all messed up. Guess I'll go ask if that's a Blender bug! Thanks a ton, again. Would you have an explanation as to why a single instance of the object sliced correctly, but two of them didn't? I'm just really curious.
Sorry, I don't know much about models, I expect someone else could answer your question.
That's very fair, thank you so much again for your help!
burtoogle 505
Hello, could you please attach the model(s) that you are having problems with, thanks.
