Posted (edited) · UM 2+ Flow Rate
I have a UM2+ (upgraded from a UM2) that prints beautifully, but with the .80 nozzle, I have to set the flow multiplier in Simplify3D to 140% to get past underextruding bottom and top layers.  I'm using 20mm/second speed and 0.40 layer height.
I have never been able to get a print sliced in Cura because I can't adjust the overall flow rate up that high.
Is this normal, or is it compensating for a problem somewhere?
Edited by Idahobie
    Posted · UM 2+ Flow Rate
    If you want full control over material settings in Cura (including setting the flow rate), change the gcode flavor from "Ultimaker 2" to "Marlin". You can then set the flow rate to anything you like.
