tinkergnome 918
You probably use the printer definition "Creality Ender-3" - not the "....Pro"
The definition for the Ender 3 has "disallowed areas" - displayed in grey on the build platform:
https://github.com/Ultimaker/Cura/blob/master/resources/definitions/creality_ender3.def.json#L15
A definition for Ender-3 Pro was added just a few days ago, it may be officially provided with the next Cura version (dunno).
markwoodford 1
I ran into the same issue on my Ender - 3 Pro, trying to print https://www.thingiverse.com/thing:2869973 which is 200mm in diameter. I looked at some settings and then it occurred to me that I had "skirt" enabled under build plate adhesion. I switched it to none and suddenly, I get the use of all 220mm x 220mm of build space. I hope this helps.
Mark
BrotherBloat 0
did you ever get this sorted? All the build volume affecting settings seem to be zeroed, but I'm still only able to make a 235x214mm object, 214mm Y dimension stays even if I set the build plate dimensions to 10x the size...
