Dual Extrusion - Pause position during nozzle heat up
BR365
Posted (edited) · Dual Extrusion - Pause position during nozzle heat up
Hello,
I use a dual printer (Dual Extrusion, single nozzle).
When there are two different filaments used with different printing temperature, the print head pauses when waiting for the nozzle heated up to the correct print temperature. But, the nozzle waits above the printing area and therefore, it creates a drop of filament at the waiting position.
It would be better, if the nozzle would move to an non-printing area to wait for heating up and then move to the next printing position. But I couldn't find an option for this.
How do You solve this problem?
Thanks,
Moritz
Edited by BR365
Wrong attachement
    • 2 years later...
    Posted · Dual Extrusion - Pause position during nozzle heat up
    I don't know the answer but you can probably enable a tower and at least it will do this warm up over the tower.  I hope.  Look for enable prime tower.
