Hello,
here is the 3mf file.
Thanks,
Moritz
Edited by BR365
Wrong attachement
Hello,
Thanks,
Moritz
Edited by BR365
No, that isn't a .3mf file, that's the gcode. Please do File -> Save !!!!!
Sorry, I took the wrong one.
Edited by BR365
No dingbat, that's still not right. You did File -> Export but you have to do File -> Save.
OK, next try.
What is the difference between "Save" and "Export", when both create a 3mf file but with different sice?
Greetings,
Moritz
Export just includes the model(s) but Save includes the models and the settings. I have requested that UM alter that menu to make it more obvious but they weren't interested.
Anyway, when I slice your project I don't see so many direct travels as your image shows, what version of Cura are you using?
I use the latest Version 4.5
Moritz
Actually, I have the exact same problem here!
And it's driving me nuts 🙂
Geert
Same here, I try to use combing to avoid stringing but it is definitely not working as it should, and behaving precisely as described in this post.
burtoogle 505
Hi, please save the project file (File -> Save) and attach the .3mf file to this thread so we can see what settings you are using. Thanks.
