S5 print initialization sequence suggestion
kayakbabe
Posted · S5 print initialization sequence suggestion
Sometimes , usually for me due to needing to clean the glass, the print job stops because the s5 can’t do the auto leveling procedure. I would like to suggest that the auto leveling occurs prior to priming the tips. Changing the sequence would save filament since so much is extruded with every attempt to print. If the auto leveling can’t complete, then no filament would be wasted.
      • 31 replies
      • 25 replies
