Segmentation Fault upgrading to Cura 13.11.02
chelys
Posted · Segmentation Fault upgrading to Cura 13.11.02
Also crashes on my Retina MBP running 10.9. I can complete the first run Wizard ok for the UM2, then it opens a dialog saying an error occured, and offering me the choice of quitting or opening the console. Here's the start of the crashlog:
Process: Cura [1111]
Path: /Applications/Cura 13.11.2.app/Contents/MacOS/Cura
Identifier: com.ultimaker.Cura-13.11.2
Version: 13.11.2 (13.11.2)
Code Type: X86-64 (Native)
Parent Process: launchd [209]
Responsible: Cura [1111]
User ID: 501
Date/Time: 2013-11-22 07:53:33.882 -0600
OS Version: Mac OS X 10.9 (13A603)
Report Version: 11
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000010
VM Regions Near 0x10:
__TEXT 0000000100000000-0000000100006000 [ 24K] r-x/rwx SM=COW /Applications/Cura 13.11.2.app/Contents/MacOS/Cura
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 libobjc.A.dylib 0x00007fff8a7e562a (anonymous namespace)::AutoreleasePoolPage::pop(void*) + 454
1 com.apple.CoreFoundation 0x00007fff8a615d72 _CFAutoreleasePoolPop + 50
2 com.apple.Foundation 0x00007fff94b58e4c -[NSAutoreleasePool release] + 140
3 libwx_osx_cocoau-2.9.4.0.0.dylib 0x00000001091d08ac wxApp::~wxApp() + 60
4 _core_.so 0x000000010613bd3c wxPyApp::~wxPyApp() + 92
5 _core_.so 0x0000000106186704 _ImageFromBuffer(int, int, unsigned char*, int, unsigned char*, int) + 207444
6 _core_.so 0x000000010614d9d4 wxPyEvtHandler::wxCreateObject() + 3300
7 org.python.python 0x00000001005d374b PyDict_Contains + 2251
8 org.python.python 0x00000001005f299f PyType_IsSubtype + 7599
9 org.python.python 0x00000001005bc5ad PyFrame_ClearFreeList + 189
10 org.python.python 0x00000001006715db PySys_SetPath + 1147
11 org.python.python 0x00000001006715eb PySys_SetPath + 1163
12 org.python.python 0x00000001006715eb PySys_SetPath + 1163
13 org.python.python 0x00000001006715eb PySys_SetPath + 1163
14 org.python.python 0x00000001006715eb PySys_SetPath + 1163
15 org.python.python 0x00000001005d2577 PyDict_Fini + 1975
16 org.python.python 0x00000001005d49c2 PyDict_SetItem + 114
17 org.python.python 0x00000001005d4ad9 PyDict_SetItemString + 73
18 org.python.python 0x0000000100657c00 PyImport_Cleanup + 224
19 org.python.python 0x0000000100668728 Py_Finalize + 264
20 com.ultimaker.Cura-13.11.2 0x0000000100004410 start + 13856
21 com.ultimaker.Cura-13.11.2 0x0000000100004b6e main + 1438
22 com.ultimaker.Cura-13.11.2 0x0000000100000e24 start + 52
    Firmware update - Ultimaker 2 - Firmware version: 13.11-2
    • Fixed Ultimaker 2 build volume offset so that you do not print off the glass plate.
    • Slightly tweaked the filament change procedure so there is less chance of a blob staying behind.
    • Slightly tweaked the SD-Card error problems, solving a rare case of SD-Card read errors.
    • Added LED settings to Tune menu, so you can tune down the LED lighting during printing.
    • Start heating the nozzles when the bed is nearing its final temperature, so the nozzles do not sit hot.
    • Make sure all commands are finished before starting a print or changing material. This could cause issues when you where too fast.
        • 21 replies
