Posted
· Door handle cover protects from contamination
1 hour ago, gr5 said:
Love it! I'm guessing a zip lock baggie in everyone's pocket would work also?
Yes sure, anything according to that concept. As long as it separates your hands from the door handle, and it doesn't contaminate your pockets! This is why I wanted a cylindrical object, not an open flat one like most others, so the inside would not touch your pocket lining.
My first idea was using left-over pieces of copper tubing, rain/drain-pipe, aquarium-tubing,...
Copper tubing would have the advantage of being self-desinfecting: its oxide outer layer is poisonous and soon kills germs; it is sturdy, easy to machine, and can easily be further desinfected or autoclaved if required. Maybe copper-filled filament would also work, but then you lose the heat-resistance.
Cutting plastic PVC-table cloth, rolling it up in a cylinder, and glueing or sewing together (whatever works on that plastic), also crossed my mind. So, if you have little ziplock bags, or other sleeves, that should be fine, provided it is handy enough.
This below was the original idea, to be made from a piece of rain-pipe. And then it evolved into the "vase", since I don't have piping but I do have a 3D-printer:
1
geert_2 560
