So, I did what you say. I went through the code and found that "s225" few lines after "s200". It seems cura is doing something there.
Printer iPLA standard hotend temperature is set to 190, but as soon as I open the sd file, gcode overrides the printer temperature as it should. As I said goes up to 200 and then to 215.
I wil search throught those different temp types. Right now I don't have cura with me.
Thanks a lot for your reply.
1
gr5 1,506
It might be a setting on the printer itself. I've seen this feature on some printers.
Also note that cura has many temperatures so type "temp" into the setting window in Cura.
Also you can open the gcode and search for "S215". It should not appear anywhere in the entire gcode file. If it does then it's a cura issue. If it doesn't then it's a A20M issue.
