Posted · Variables in Material tab
Hello everyone,
I tried to figure this out myself but wasn't able to. So please excuse me, if I overlooked a solution to this on the board.
When I set up my materials from a default printing template I have for example printing temperature as a varibale for what I set in my material template.
Now if I create a copy of that printing template and just once alter that value to whatever temperature I think of and close Cura (or save the template forgetting I changed that value), I can't get it back to this variable.
Is there a way to do that?
In addition - is there a way to set build plate temperature initial layer relative to build plate temperature (e.g. 1st layer 10° lower than normal build plate temperature)?
Regards,
dtose
    You can do that by installing the Material Settings plugin. It should show you a "revert arrow" if you change a value on the Print Settings on the Material preferences pane.
    Yes, but only by editing text files, and not for values set per material in the Materials pane of the preferences.
    • Thanks 1
    Posted (edited) · Variables in Material tab
    Hello ahoeben,
    thank you for your help.
    As with your octoprint-plugin, this plugin seems pretty helpful to me. Would it be possible to include initial layer flow in this plugin?
    I like to change flowrates for the first layer. So if I were able to adjust all the material related settings in the material tab / your plugin, it would be a very comfortable solution.
    Quote
    Maybe I didn't state my intent very good. What I meant was:
    Is there some way to get the previously saved 75° back to the variable it was at the beginning (linked to build plate temperature).
    It might seem like a minor thing, but I'm pretty new to printing and still experiment a lot with the settings. So it happens to me from time to time that I forget to revert changes before saving the profile. That results in having to create an entirely new one to get the links to other settings back.
    Oh, and what I wrote in my first post isn't entirely correct. Just quitting Cura won't save the changes finally. I can revert from there.
    Best regards,
    dtose
    Edited by dtose
    Sure. See Extentions -> Material Settings -> Configure Material Settings
    Yes, by "removing" (reverting) the setting in the Print Settings tab on the Materials pane of the preferences, with the Material Settings plugin installed.
    Once again, thank you very much for your work and help.
    That plugin is a real help for me.
    That doesn't work for me if I set a value in curas print settings.
    But now I only have to create the printing profile once and can adjust with your plugin 👍
    Thanks!
